Worthless? Nonsense! They are good for something.
Tore my engine apart today (a second purchase), down to the last single piece I can pull out. The engine is a Nantong (NT) 80/66 cc. Manufactured in April 2009. $119 kit. I thought "cheap". Both top and bottom of connecting rod are needle / roller bearings.
Why tear it apart? I snapped two (2) head studs from over-torquing the puny 6 mm studs to 12 ft-lbs. I should have stopped at 9 ft-lbs. Today, one darn hole stripped clean out. Made engine totally useless. Tomorrow, I drill out and tap to accept real studs... 1/4 inch (or larger) Grade 8 fine thread bolts. This is an experimental engine; I plan on experimenting!
My first engine started just fine and is putting along just fine. Don't have enough miles on it to have real problems.
What I learn from this engine will be applied to my next project: Assembling from parts and pieces a Chevy V6 for oval track competition.
Inexpensive or top quality? Almost never can you have both.
