hi i got some info about how to make a clutch mod that is extremely effective, someone might have thought of this before, but ill talk about iot. first i take off the clutch plate clean it up, now the fun part. i took a 3/8 drill bit and drilled 8 holes in a even design around the clutch pad, at prob 3/8 from the outside of the edge. then i took the plate and counter sunk the holes. filed the lips and sanded it. i installed the plate and i found a extreme difference. the plate grabs alot harder and and without having to get the bike up to speed, i still have stock clutch pads and they wear a whole lot less then they did before. i got the idea from the preformance brake routers on cars, and the 3-stage clutch that Rice burners use. it works real good and it wears alot less. ill get a pic here tomorrow. that my 10cents worth. hope it gives people ideas, it be cool if i was the first to think of it.
P.S. the slant head rocks when you have a 27 tooth sprocket, and perfomance carb and a tuned pipe.
