xtremespeed2102
Hey,
Ive been doing quite a bit of lurking and searching and have an idea of what my problem might be but figured Id pick your brains. Anyway, I stopped riding the bike for a while because of this squealing noise that sounds like it is coming from the motor.
After some searching I narrowed it down to either the clutch or the main bearing within the motor. I adjusted the clutch as per some directions that came with the motor. The clutch works a bit better now but there was never anything wrong with it.
The squealing comes regardless if the clutch is engaged or not. Its harder to hear when the motor is engaged because it is running. It does not seem to vary with rpm but is intermittent.
Is the main bearing or bushing shot? I bought the motor from King Motor Sport and have almost 20 hours on it. I am quite capable of tearing down the motor, but have not had time to do it until today. Its been some time since its been ran. If I tear it apart what should I be looking for? Can I purchase the bearing anywhere like say tractor supply or Napa or something of the sort?
Any suggestions will be greatly appreciated.
. I used a plastic hammer to tap them and the shaft out it will come out from either side just don't beat it hard. Don't take the bearing on the clutch apart like I did unless you want to play pick up cause those little bastards I mean balls will scatter to the four winds and then some. You can lube them with a light grease with a needle or machine oil. As for the bearings clean out the old grease and pack the cavity with a good grease the clutch mounting stud when pulled out makes for a easy way to grease the bearing. you might try that first but if the thing is crying it will be faster and easier to take apart and fix it. Good luck and have fun
