Adapting Briggs Build to accept bigger engine
Last week I adjusted the intake valve lash that was out of tolerance. Gap between tappet and valve stem on the intake valve was 0.0015 inches.
The intake specification is to be between 0.005 inches and 0.007 inches.
With grinding the valve stem a bit with sand paper on a porcelain hard surface, I got it level ground after seeing I was going on a tilt at first. Also lapped both intake and exhaust valves in there seats and the result I ended up on target was 0.006 inches in the center or the range for the intake specification.
Saturday was out at Mendocino National Forest again at another location Stonyford. There was for Sunday a Enduro event and left although maybe trails would have some open not for the event. I was also maybe interested in watching, but they said there was not really much any place to see except a few areas. Also weather was supposed to have rain again, but it was clear.
As for my bike not restarting after it was run hard and got hot, this was not happening anymore and worked flawlessly. Only thing the area had also lots of rocky trails and dirt roads, so I found a few paved roads for short distance they allowed, but they are not that interesting. The mud puddles I usually avoided if I could, but near leaving time I went few times right through the center of deep mud puddles. These ones differed from think viscous mud type I had done before. There was maybe 3 inches of water and they 3 inches of viscous stuff underneath.
The past ones I rode through years ago had maybe 5 inches of viscous mud and if you turned the handle bars your sure to take a spill. I did not do that then or this time either. The bike is only 3.5 hp and no match for the very powerful trail bikes there.
Not very many people see a home made trail bike so quite a few people ask questions what is this. I though one person said something who was with a group of people that saw me riding there, it was this one person that said something like about finishing riding or being there the next day in the Enduro event. Only later I though maybe he was feeling I should have been going faster.
Going around banked turns and through mud as well as large rocky surfaces, I can't do as well as more powerful trail bikes. Those bikes have tire width 3 times that of mine.
I had good fun riding and the next day cleaned my riding gear some covered in mud. The bike I will clean some later, but though I did only pay 5 dollars to camp, the riding is paid by my 2 year OHV registration, and I got free under coating on my bike.
I have to shim my helmet cam mount it is at the maximum to point upward, but it misses seeing a lot higher up in view. I guess I am leaning forward and my helmet may be pointed down some. My eyes are looking up and I thought it was going to get good movies.
Maybe I will get that fixed soon, but I will get a link from Vimeo for an upload I am about to do of that road scene where I open the throttle up.
You will not see video here, just see it at Vimeo site.
When you click on the blue area "Watch on Vimeo you will see video.
I am replying to self as the Nov 13th 2017 post has the info about the intake valve way out of spec.
Back then there was almost no valve lash space between tappet and valve stem bottom.
Gasoline was sucked up from venturi effect the wrong way at the paper air filter making the engine not run till it dried out. The piston on compression stroke had intake valve still staying open for like half the travel during compression.
So, it was about a year and a half ago I bought a cylinder head gasket and I was fairly sure it was valve lash again. I could have just looked at the valve lash and not bothered even taking the head off. But the color of the wet area on the paper air filter was so ingrained in my mind that I felt it was valves out of spec again.
To my surprise when I found that the way I set both intake and exhaust valve lash at 0.010” a bit of extra gap for both valves, was still the same at 0.010”, I though now what.
I inspected the wet yellow area on the paper air filter and it as it turns out is not gasoline but oil mist this time.
Before it was probably both gasoline from valves out of spec and breather oil spray.
The breather actually routes into the throat of the carb, between it and the air filter.
The oil mist I think should not get the paper air filter coated with oil mist. The direction should be primarily just into the carb throat.
Maybe some kind of pressure from the crankcase and turbulence has it go both directions?
Now I have understood that the Briggs engine tilted back about 15 degrees, along with going up some inclines doing motor cross in the woods could make this a need for a catch can.
I have a stainless-steel water bottle with a plastic screw top. I have some brass tubing and rubber automotive OK for fuel / oil and high temp Copper RTV stuff to make the catch can.
I was ready to drill the cap for goes into with the metal tube going nearly to the bottom of the bottle. The goes out just a short piece of tube to have the oil stay at the bottom of the bottle and only mist out the top. Maybe some additional filter to stop the mist of oil and just let fumes by the exit of the bottle to go back into the intake.
The weather was unusually nice for one day and I got a start till now looks like a week of rain. Continuing the work when it is dry again.
Question:
I did mention to a store proprietor about my project and he mentioned about blow by being a cause. I’m not sure if he knew the brings engines of old have a pencil size hole the goes from inside the crankcase by the cam for the tappets and right straight up to where the springs for the valves are and the breather.
Do overhead valve engines besides actually not needing to grinding valve stems to adjust to get gap back, also do not have problem with engine tilt causing oil spray into the carb throat?
I mean the blow by if it was really that bad, then I would probably have the engine being less powerful and less compression maybe too.
I did not notice less power, just a paper air filter that has oil coating about the center third of it in a stripe. Then it would become hard to start and I could get stuck having to replace the air filter just to be able to start the engine again.
MT
The weather looks OK for some days and I plan on start making the catch can.
Would it be a good idea to use some kind of additional screen / filter or something besides what is already in the Positive Crankcase Ventilation one way valve that is by the springs for the valves. I know I think they have sort of a mesh screen of some sort inside?
The catch can (bottle as it is) with a tube going in to it, from the PVC on the engine, will extend to about 2 inches from the bottom of the SS Water Bottle. The tube coming out to go to the carb intake, will be just connected inside the bottle inside to a depth of an inch.
I thought of putting some kind of screen just below the connector going out of the bottle.
What I mean is I could have the bottle vertical dimension of about 7 inches help along with gravity keep the large droplets spray of oil in the bottom, but if any got close to exiting the bottle it would have to go past a mesh screen. I have an extra pre-filter screen that is used normally in front of the paper air-filter to keep out some particles on this Briggs, but then go to through the regular paper air-filter.
Between the paper air-filter and the throat of the carb, the routed back oil mist from the PCV is sent right there.
So, if I use one of the pre-filter screens on the catch can bottle inside it can possibly help lessen chances that oil mist will still be so great that it can swirl around as I guess it has been doing and clog some of the paper air-filter making hard or non-existent starting issue.
Pics of pleated paper airfilters. One still new unused in bag. One with lots of oil soaking. One other only slightly used no too bad.
At one time with valves out of timing and gasoline thrown at paper airfilter I though of saving money with special foam for a custom airfilter reusing the gasket from an old paper filter's bezel. I could clean the filter as it is foam not paper with special cleaning fluid they sold along with the special foam. Waste of time really, need a catch can!
Prefilter screen with foam looks like I can clean probably with the stuff I bought for the funky foam make your own filter. I can put inside the bottle.
A JEGS brand PCV that has a filter screen in it but bigger than the one that mounts on the engine made by Briggs. Could use two in tandem? Still in any case need the catch can device.
All parts getting ready to assemble.
Cleaned some of the carbon and old cylinder head gasket off.
PS I bought the zinc stuff you add to gasoline to help with valves, but primarily it is the oil getting too much and fouling paper airfilters.
Maybe paper airfilter that self replace themselves;)
It looks as though I have no room near by the carb and pcv to put a catch can.
I am looking at putting the catch can up by the gravity feed gas tank near the front of the bike. I also looked to be sure no sharp bends in the hoses or too close to the cylinder head that could cause a problem.
If I use two hoses each 3ft, for a total of 6ft, would you think that the catch can mounted where I have space would be alright with all that length of hose routing?
Another question I have is how the catch can that was mounted up high, in a specially designed system could allow the cooled down engine to put the oil it catches, back into the crankcase.
I know that the gravity from up high makes sense, but the one way valve (the PCV), is not going to let oil back in that way.
Would the engine have to be turned off and cooled for it to automatically allow the oil to go back to the crankcase with a separate valve?
Temperature sensitive valve that goes into crankcase opens at the a T connector very close to the PVC......?
MT
https://motorbicycling.com/attachments/1111171533b_film1-jpg.96652/ See on the photo, opposite of gas tank to have a catch can.
So I got the start of the catch can going. I was to drill the two holes on the cap of a metal bottle with plastic screw top. The cap I drilled or tried but just the center punch cracked the very thin plastic. Not too big an issue though. You see I took a torch to heat the steel tubes that I were to drill holes in the cap for them. Very nicely done. Just need to beef up the inside of the cap with a rubber or cork stopper and also drill and RTV in place these tubes.
Question if any of you know about torches.
The plain Bernsomatic Torch I used with a propane bottle would not light unless I use a gas burner on a stove to place the end of the torch tip with the gas on. A match or a lighter just gets blown out. Even on the lowest setting I could have on the torch the same thing happened.
I did find the little filter of some sort before the tip on the end of the tube coming from the torch valve had a blackened look. I cleaned it off and saw the yellow screen of sorts. This made no difference. A full propane bottle or one near empty both would light and work fine but would need a gas flame of the stove top, not a match spark, or lighter.
MT
MT
I am guessing that the regulator somehow is messed up, it does not go to a low enough setting to not blow out a lighter when trying to ignite the torch. Solves that. I just use the kitchen stove and it will not blow out but lights the torch.
Now that I have the Drill Press I have part of a combo old Rockwell Delta Homecraft from way back 1952 mfr year, I thought I would clean up and use the Sander as well. The Saw Table and 4" Jointer, I will just not bother with right now.
I tried to find out where the pulley went to use for the Sander. The circular blade from the Saw Table gets remove to allow a pulley on one end of a shaft that has another pulley going to the motor. The with the Circular Table Saw Blade removed I need the pulley to connect to the Sander.
I looked at the Jointer that has a pulley on it and it would fit just right on the Sander. Both Jointer and Sander are not used at the same time, so I attempted to remove the pulley from the Jointer.
Oh, what a pita! I found that the shaft that the pulley is on the Jointer had a mushroomed end. That would not allow the pulley to come off. Sure, I took out the set screw on the pulley, it was not properly on the flat spot on the shaft.
Nope, it was about 180 degrees opposite the flat spot on the shaft. Who did that.? Additionally, I could see if the pulley was put flipped around as opposed to the way it was, the flat spot could align with the set screw. It only allows half the set screw to align with the flat spot the way it is now.
I went to using a Dremel with grinder and cutter wheel to get the mushroomed end of the shaft cleaned off. So then it then could move about a 16th of an inch more toward being able to come off. Gee, oh well.
There is something else, probably the flat spot or whatever that marred the shaft and I spent so much time already, I am about to give up and just leave the pulley on that shaft and buy another for the Sander operation.
I could see where I have put my small flywheel puller to help remove the pulley. But you know I will probably be at the hardware store to find a pulley I could use. Maybe I must go out of town or online, but oh well.
Tomorrow I can just get the Drill Press set up by using my hoist to hold it in place to bolt onto the Rockwell Delta Homecraft Combo. Then onto making the catch can.
The Linkbelt that you can make any length belts from I have a bunch from finding out they were not good enough for my motorbike sheave, but for this on the Combo, I think it will do fine. Not to bother buying anything more when these Linkbelt pieces I have sitting around gathering dust nee some action!
I am getting a new power switch and have new wiring as well as a paddle switch that I think I will like to have as a back up shut off where a knee as well as hand can shut the motor power off.
Then onto finishing drilling holes in a piece of closet hanger rod wood for the two tubes for the catch can bottle. I will glue that into the bottom of the bottle cap.
Long time with other stuff getting in the way of this proceeding very fast, but probably, hopefully done before a month passes by. The registration renewal for OHV is already in hand. It only cost 50 dollars for two years I think it was. No, I don't think it is worth it to put planned non-operation.
MT
