2007 schwinn whizzer
I have a 2007 schwinn whizzer that needs a few things, i was wondering if anyone could recommend what type of carburetor i should use to replace the old one, and where i could find and matching idler pulley. Thank you.
wrench
826
1,189
93
So Cal
If ya got a 2007 Whizzer engine then You'll want a 22mm carb
This carb says it's got a #100 main jet You'll want to use a #84 or #85
insight3fl
9
23
3
38
Wrench (If you're still on here) or anyone, I have a 2007. whizzer Phantom II and have the same question about a carb. The site that is attached looks like it's gone. Do you have any suggestions about what/where to get one? Thanks for your help.
Post is 2 years old. Paul passed away more than a year ago and the final sale of items took place earlier this year. Jo lin from Taiwan (E-Crater) still has many parts but shipping adds quite a bit to the price.
my ebay
  • Like
Reactions: fasteddy and wrench
wrench
826
1,189
93
So Cal
WC1 Manufacture in Taiwan made your 2007 Whizzer
You can order from them but It's gonna take a while and cost more because it's shipped from Taiwan
You can also find a wide selection of 22mm carbs on E Bay and Amazon
Maybe try search Whizzer Parts on E Bay
Tony01
1,848
1,960
sf bay area
22mm may be the size the rest are but that’s way too big for that size motor. I’d go 19mm MAX. I think about 16-18mm is best. Far as which exact carb that’s up to your intake manifold bolt spacing and such. Pretty much you need a 19mm slide carb with the correct bolt spacing. Measure the original carb or intake and get the same.
  • Like
Reactions: fasteddy
Tjpthompson
3
4
3
52
I'm seeing several that say for 2000-2005 Whizzer. Is there a difference on my 2007? Sorry I just want to be sure. Thanks again for your help.
  • Like
Reactions: fasteddy
wrench
826
1,189
93
So Cal
NE-5 2005-2007 has a bigger intake valve 24mm and came stock with a copy keihin 22mm carb
1999-2004 has a 22mm intake valve and first came out with a really good Honda 16mm carb then switched to a copy kehin 19mm carb
The 22mm carb will probably come with a big jet, use a #84 or #85
PZ 20mm carb is also a good choice as that's what Cruzzer used on their Version of the NE-5
  • Like
Reactions: fasteddy
