Rusty_Nail
See attached pics.
Is there a way to weld it or will I need to get a new frame? Also would it be safe to ride it like that or would it not be recommended? I’ve never had a frame crack on me.
Looks like the top tube to neckWhere is the crack located on the frame?
Get this. I really love it.I honestly have no idea if its aluminum or something else. I have no access to a welder or someone that can fix it for me, so I'm still leaning toward a new frame. But How can I tell if its steel? I do know that whenever I would ride it the frame would vibrate a notable amount if I was on WOT. One reason I was thinking about another cruiser frame is so I can use my hub mounted sprocket setup. I hate having to use those stock sprockets.
Although it is a Walmart bike, the frame itself is damn impressive. It's made woth thick tubing and is surprisingly heavy compared to other frames. It is lacking with the stock wheels, but OP mentioned using his current wheel setup. Not everything is poor quality just because it's from Walmart.Again it's Walmart quality. Look for a frame from the 1960's or 1970's or even earlier. Craigslist or Facebook market place, second hand stores, bike shops old bikes pile or even a scrap yard if you have one near you. Check out Sportsman Flyer if you want the absolute best frame going. It's a lugged frame so there's no butt welded tubing.
Steve.
Haven't worked on a Walmart bike yet, in which I didn't have to true the wheels. Low quality components and very poor assembly. On the former pedal only forum (YA Cycling) I told people, if they must get a Walmart bike; get one still in the box and have a reputable bicycle shop assemble it.Although it is a Walmart bike, the frame itself is damn impressive. It's made woth thick tubing and is surprisingly heavy compared to other frames. It is lacking with the stock wheels, but OP mentioned using his current wheel setup. Not everything is poor quality just because it's from Walmart.
The Huffy's were not too bad,Haven't worked on a Walmart bike yet, in which I didn't have to true the wheels. Low quality components and very poor assembly. On the former pedal only forum (YA Cycling) I told people, if they must get a Walmart bike; get one still in the box and have a reputable bicycle shop assemble it.
The Hyper won't crack on you. I would definitely swap over your wheel setup and run rim brakesI know I've had a good 3-3.5 punishing years on that frame and from my experience with what I put it through, it's held up well until now. If my crank was better balanced I'm thinking the frame would not vibrate as much when I would ride it.
