Is this a crack in my cruisers frame?
Sidewinder Jerry
2,054
1,049
Rockwood, TN
Is there a way to weld it or will I need to get a new frame? Also would it be safe to ride it like that or would it not be recommended? I’ve never had a frame crack on me.
It can be fixed by a skilled welder. You're also going to need to repaint it. I suggest putting a custom made split lug on after the weld repair. The split lug will have to be welded back together once around the frame, then brazed on. This should prevent any future cracks.
fasteddy
7,462
4,938
British Columbia Canada
If it's aluminum I'd get a new frame. This is a problem with the stress of powering an aluminum framed bike that has been discussed on here over the years. Walmart level bikes are usually the first to break. Find a steel frame if you can find one you like.
The frames usually crack where the tubing is welded to the head tube just behind the weld like this one did.
Steve.
wrench
814
1,166
93
So Cal
If it's aluminum throw that frame away
If it's steel strip the paint with a wire wheel then weld a 6" sleeve (1/2 pipe) on the frame rail to the neck Over the crack
Because if ya just weld the crack it'll probably crack again by the weld
Looks like the crack is at the frame neck top tube
