Are you getting fuel?Hello i have 1976 Honda PC50 k1 lovely little moped great fun . I have plenty of spark at the plug but won't start any ideas what to try next ? Thanks Red 50 .
Have you throughly cleaned the carb? Ethanol added fuel is really bad about clogging up jets. This is why most of us long time forum members will only use a 100% Ethanol free gas.
I will try that may have some carb cleaner in the shed so will give it ago and let you know my findings . Ps will only clean the metal parts of the carb . Thanks Red 50 .Take the carb apart and spray it down with carb cleaner. Carb cleaning kits are helpful also. Only use carb cleaner on metal parts. For non-metal parts I like using Sea Foam.
Hello thankyou for the advice on the carb cleaning for my Honda PC50 is it ok to use an airline on low air to dry off ? Ethanol in modern fuel does block up the old carbs . Great little moped it had a hesitancy on acceleration before the none starting problem . Plenty of spark at the plug . Thanks .Make sure you completely clean out the carb jets!!!
Just because you have fuel into the bowl doesn't mean it's actually making it into the airflow, (& into the engine).
. There is a small spilt in the float in the carb not sure how long that has been there ?
Just a small spilt on one side of the float not sure how long it's been there ? Had the PC 50 since March 2022 ran ok once i got it going took awhile as off the road for 40 years . Can't find a supply of new float to replace . Is it possible to glue it with a glue that is compatible with petrol ? Thanks Red 50Whatcha mean there's a split in the Float. Is there a hole in the Float?
If there's a hole in your float then that's your problem, or at least, one of your problems
While I've never repaired a carb float or can't recommend what glue to useJust a small spilt on one side of the float not sure how long it's been there ? Had the PC 50 since March 2022 ran ok once i got it going took awhile as off the road for 40 years . Can't find a supply of new float to replace . Is it possible to glue it with a glue that is compatible with petrol ? Thanks Red 50
Hello many thanks for the advice will try that . RED 50Gas and alcohol resistant epoxy.
My carb float is Solid so can't fill up with gas . Has a very small spilt on the side of it . Just need a glue which is petrol resistant . Thanks Red 50While I've never repaired a carb float or can't recommend what glue to use
It can be done, Float just needs to be air tight so it don't fill up with gas
OK, if it's a solid float that little slit won't hurt it, Don't even play with itMy carb float is Solid so can't fill up with gas . Has a very small spilt on the side of it . Just need a glue which is petrol resistant . Thanks Red 50
