RED 50
OK, if it's a solid float that little slit won't hurt it, Don't even play with it
Thankyou that's good news because I've failed to track down a replacement . My carb cleaner arrived today but it's the sort you add to the fuel in the tank not a spray so hopefully it clean the carb as planned . Half on the carb and the other in the tank ? Red 50
Hello my Honda PC50 has spark and the plug smells of fuel so may be not a carb issue ? Ran some cleaner through it and checked the ignition timing set now at 12 thou . Not starting ? What else to check ? Thanks Red 50
