Springer seat without fabrication
Zarro
30
6
8
18
Is there a good type of springer seat out there that doesn't need fabrication? I don't have access to welding equipment, but I can modify the frame by drilling into it if necessary.
Ideas?
Venice Motor Bikes
Mar 20, 2008
7,337
1,981
Los Angeles, CA.
So let me get this straight?, You're concerned that a heavy duty steel fork might snap, but you're considering drilling holes into an aluminum frame???
'Interesting'
Zarro
30
6
8
18
'Interesting'
How else would you mount a springer seat without welding?
That is what I have heard about those forks, I was just asking. I am still very new to this hobby.
And the holes created for some bolts for a seat aren't huge. I could even get a duel-threaded steel rod to put through to make up for drilling the holes.
Mossy
1,128
819
I don't like aluminum frames... I'm heavy 240# and can snap a steel frame with no engine going 1mph... It's the vibration that aluminum doesn't like and chasing cracks in a frame all the time isn't as bad as steel and steel is more forgiving to weld... My first mo-bike had about 4lbs of mig wire in it after about 4 years of flat beach road use... Aluminum... Gets it's strength from a thin layer of oxidation on the surface... Anodized or polished helps smooth out the surface... Steel is strong all the way through the metal... And don't drill holes anywhere on any frame... Weld in gussets close gaps round and smooth everything out so it's one solid piece... Bicycle is made to flex... A motorized bicycle is made so it doesn't... Or not as much as best you can... A BmX Dirt jump frame in 26" would be the only aluminum frame I would consider if I absolutely had to have aluminum... And it would fold where a chromolly DJ frame would total a Prius ;)
  • Like
Reactions: Tony01
Zarro
30
6
8
18
I only weigh 150 and will never weight more than 190, I am pretty tiny.
I have seen 212s be put on cdhpower felt fakers that have lasted for years with heavy dudes riding them.
Mossy
1,128
819
Ideas?
Everything is going to take fabrication... $100 harbor freight welder and grinder cheap hood starter kit... Get some hardware cloth and one of those stainless fire extinguisher you can change with air and water... Drilling and building something like an erector set isn't going to be the way to go... Motorized bicycle will teach you to be a metal fabricators.. don't hire it out just watch U tube ;)
Mossy
1,128
819
I've seen guys that are tiny... Big and there all getting there frames welded or there swapping frames... Unless there pushing it around there living room for years it's getting worked on constantly...
Zarro
30
6
8
18
Just use the search. Most the stuff you are asking has been done before.
Those guys with 212 fakers don’t ride a lot, and a lot of them compromise their oil systems to fit the frame. Bad setup. As mossy said you want steel.
What do you mean compromise their oil? The oil access spots are still accessable
Tony01
1,848
1,960
sf bay area
Something like this... But it's not a bicycle with those engines... Unless you walk like John Wayne it's impossible to pedal around...
Yeah that’s a good frame there. Zaro use the SEARCH and you’ll find a thread where I built a 212 motorcycle.
  • Like
Reactions: Zarro
