What size is rear wheel hub
Oops. There is no delete, so I'll just leave this mistake post here LOL
There should be a delete on this site but Nope
Whatever size adapter fits lock it down with 660... You can also put set screws (3) to bind it down also... But you only have 10 minutes to get everything together and give it 24-48 hours to completely cure... Blue lock tight on the threads and a torch takes it off
638 will work also and probably better because it's green
You can backspace and erase it all the next time...........Curt
What I'm saying is, If I make a post and within the first 10 min I can edit but I cant delete my avatar, user name from the thread
I post again to show an example
Ya see I couldn't delete, I had to leave something so I just left a period
Sorry to get off topic from the OP
Just pointing out that there isn't a delete
Maybe there should be a delete button
Actually a couple years ago i did ask the Administration why there wasn't a Delete button
I was told because when someone goes thru the trouble of a lengthy post to help someone
Then the OP Deletes his thread it's unfair to the guy who went thru the trouble to help, that info can be helpful to others
So there is no delete of posts or Threads.
But ya get a short time period to edit
This post about the :) mistake post and my post about these posts should be deleted... laff
