2005 Whizzer with charging issue
Timbo
Hi,
I was hoping someone had seen a problem like this and solved it.
I have a 2005 Whizzer that runs fine as it runs on the mag. But it does not charge its battery and power the lights. Put in a charged up battery and it will power the lights until it normal would charge the battery (2000 rpm?) and the lights shut off when rpm drops back to idle the lights come back on. This will happen until the battery is dead.
I do not have a wiring diagram showing the voltage, but I do have another 2006 whizzer that charges perfectly. My first thought is to swap out voltage regulator as it picking so voltage from the coil to do whatever is killing the lights. But I hate to risk the working electronics.
Any suggestions on how to proceed?
Get a new Voltage reg
It's OK to swap it out with your other bike just to make sure that's what the problem is.
If The Voltage reg is not the Problem the check the wiring harness
If it's not a bad electrical part or a loose connection at a plug or ground
Probably gonna have to unwrap the wiring harness and look for a broken connection
There's a spot in the harness where all the grounds are joined together
I would check that spot
Basically it's located in the fattest part of the harness
Or just get a 2 stroker and clip the white wire :)
Your crazy It's a Whizzer, the bike still runs it just don't have lights
Someday if you ever get a Whizzer you might understand LOL
I got a 70's Schwinn home built whizzer frame just to punk the whizzer world will a 2 smoker version... Just looking for a decent front fork for it... :)
A little premix would help fire this up...
I got an award !! Thanks king wrench...
Find yourself a completely free slots these days is a very difficult task, I would recommend that you go to this site free casino slot games for fun free slot machine only here can find yourself a good opportunity to play in the most memorable and cool (give only available at this time. I would recommend that you go to this site because here you can find yourself reviews on the best slots and choose for yourself here the best free slots in which to play for real money.
I gamble enough on buying parts and get enough of a thrill from that
JUNK MAIL
