What should I install next?
Chris7420
56
22
8
24
Wow, 52mm bore, that's got to be pretty fast. That's something new, don't know how good they are but it's got to have more torque than standard China girls. But to be honest, my bike goes fast enough, I can hit 50+ mph if I really wind it up, but really, I don't need to go that fast on a bicycle.
That’s wicked man. Mine goes 50 KMH winded out.
Testname111
334
169
43
Try new electrical system, I'm using bbr super magneto and stage 2 Cdi with a car ignition coil ;)
  • Like
Reactions: Tyler6357
Testname111
334
169
43
Ive thought about installing a reed valve but I’ve read a lot of bad reviews on reed valves of people saying they installed one and it made they’re bike slower, I even saw a video of a guy who dyno’d an engine before and after installing a reed valve and it made like half as much power.
Can I take my reed out of my Athena cylinder to go faster?
Chris7420
56
22
8
24
Does it make a difference? Did you’re bike go faster after installing those?
  • Like
Reactions: Testname111
Tyler6357
1,293
294
83
Santa Barbara, CA
Did you get a performance increase using that?
Chris7420
56
22
8
24
This is the reed valve that I got:
They don't really show you the 4 peddles but they look just like this:
I also got a windowed piston similar to this:
I also got one of these larger intakes for it to fit my Mikuni vm18 carb.
I ordered a reed valve and am trying to find a window piston, do you know if this will work? It’s says it’s 47mm and has high wrist pin. I know my engine is 47mm bore and type b wrist pin. https://www.ebay.com/itm/402186052573?hash=item5da42823dd:g:PgEAAOSwsvVeHhYA
Tyler6357
1,293
294
83
Santa Barbara, CA
That looks like the right one, although I don't know how good those double windowed ones work, I got one with the large window. I guess it would be okay, I'm just saying I've never tried those. I saw this one with the large window but it says 48mm instead of 47mm, I wonder if it's really a different size or maybe a typo.
You can always get a non windowed piston and just cut your own. Just install the piston and after you get the cylinder on use a sharpie and put it though the intake and mark the piston, then remove the piston and cut it with a Dremel tool.
Chris7420
56
22
8
24
Does the window piston really make a difference? I got the reed valve got it all installed, I didn’t change jets or anything just bolted on the reed valve it seems to run good how it is maybe a little lean I have to get a new spark plug and run it a little bit so I can read it. It has a little bit more power and it goes 5km faster now at WOT and it doesn’t 4 stroke at all anymore even at WOT which is nice but yea I thought it would get me going a little faster, I want it to 50 km/h without winding out the engine so I can keep up with traffic.
  • Like
Testname111
334
169
43
I think only way is with a carb that has a bigger intake slide/barrel slide hole.. Demintions more air in = more out saying?
Testname111
334
169
43
Even with reed as my setup is the same carb as Chris 7420 and with 36 tooth gear I only get up to 30mph
Chris7420
56
22
8
24
Can you confirm if it’s the window piston or the better carburetor that got you’re bike going faster?
