Just want to show you guys my bike and looking for some advice on what to install next, so far I’ve installed a kinbelle fat belly pipe and I cut the muffler off my original exhaust and fitted it to the end, I also enlarged the hole on the cap. I installed a high compression head as well and set the squish to 0.030” and I have a sbp air filter. I haven’t installed it yet but I also ordered a 36t sprocket, currently I have a 44t. Also wondering what you guys think of my spark plug colour, is it rich or lean? Im running whatever jet it came with and the needle is set at the highest position cause that seems to be where it runs best and 4 strokes the least. I use champion 306 spark plugs cause they never have the ngk ones in stock I believe the champion 306 is the same as ngk br6s though. My bike goes about 45-50 km/h but at 50 the motor is pretty revved up, I want it to be able to go 50 easily so I can keep up with traffic without reviving the motor out to much. Links below to all the parts I used.
sickbikeparts.com
motorizedbicycle.ca
Air Filter - Low Profile Chrome
Motorized bicycle, motor bike, electric bike, ebike, pedal assist
66cc / 80cc High Performance Head
Compatible with GT5, GT5AWoody WoodPecker's High Performance / High Compression run cool head.Brushed aluminum finish. 6cc combustion chamber; Means high compression. It Fits 66cc and 69cc engines using M8 head bolts and 47mm dia. pistons. Extra cooling fins and extra mass means better engine...
motorizedbicycle.ca
