obesepolice
Im rebuilding my bike again with a 79cc predator. I need a transmission for it, but im not sure what to use. It will have the governor removed, 18lb valve springs, ported and milled head, exhaust and a 19mm carb.
Do I just use the standard clutch and jackshaft set up that comes with the kits, or make my own from better parts? Help with a parts list would be fantastic.
Grubee also makes a drive belt setup that looks like a quality piece of kit. allbet the gear ratio is abit steep. but i can change the ratios around
EZ motorbikes also has one but i cant seem to find any info for it.
there is a torque convertor but everything im finding is for a 3/4" shaft, i know you can use an adapter but i dont know what all that involves.
any help you guys can give me would be great
