I have a basic Chinese motor. recently, I upgraded from my leaking NT carb to an HP carb. I put the new carb on and go for a ride, it runs great. the next time I ride I heard A lot of clicking, coming from around the piston cap. I bought a new piston cap gasket and double stacked them, I was already having some compression issues with it because I'm unable to get one of the bolts down so tight. going on my test runs I started with choke on and I could hear my piston physically turning, but it had zero power. the throttle cable in both the handle and the carb ends are functioning fine, I believe I have the idle screw tuned right but I'm not familiar with what this carb likes. while I was riding with choke on/halfway, I noticed that really compressed air was shooting out of my carb, shooting in bursts consistent to the throttle I was giving it. I immediately bring my bike home and take off the cover of my carb to see black oil and gas splattered around. I take off the carbs bowl, the gas inside is still pure, and rinsed my jet (I'm unsure of my jet size, I have heard people take the jet from the NT carb and put in in the HP, But I haven't tried.) the jet and needle going up looked clean but I gave it a few blows (pause) anyway. I check carb to manifold, manifold to motor, motor to exhaust, all gaskets and ports are fine (one thing I didn't check was the end of my exhaust.) At this point I still cant get power from my bike. I then took off the motor cap, spark plug is a good chocolaty/mocha color, so it the top of the piston but lighter in color. I then took off the cylinder housing (I don't know proper terminology, But the piece of metal that has exhaust/manifold ports) everything looked clean, debree free. I then rolled my bike with the cylinder housing on, cap off, and saw that my piston seemed to be working fine pumping up and down.( Something I did notice but I don't think matters was that the piston head would get low enough to reveal the exhaust port when looking from the inside, but never gets low enough to show the carb/manifold port.) I put the cylinder housing and cap back on and go for another test ride. keep in mind, I didn't actually do anything when I had the cylinder housing off, I just took it off, inspected, and placed it back on. all the sudden, my bike actually gives me a little power, just enough to get 10-15 mph's, which is way better because before I was getting nothing, and the pressurized air stops shooting out of the carb. I am only able to get it to give me power with choke fully off, if chokes on it bogs down/has zero power.
I have no idea what's wrong. I thought about the spark plug being bad but it worked before I had the HP carb on and for a single ride with it on, can they go bad that fast? I read a little into someone's similar issue and they discussed how piston heads can blow air back through the carb which is what I was experiencing, I just couldn't really understand what they were talking about in what types of carbs work for whatever types of piston heads. I have experienced gas in the magneto case, but not very recently and with the NT carb. I have no Idea what's keeping my engine from giving me power. the few things I can think of is that there's still scuffs/debree in the cylinder, I dont have a piston head that matches with the functionalities of my HP carb, the spark plug or cdi isn't functioning properly. I haven't tried putting the NT carb back on but I really don't want to use it. Does anyone think they got any advice to help me out? i really want my bike to work.
