Thanks Tom, I've considered some type of mounted transmission and haven't cut anything on the frame yet so it's very much an option. I was thinking of mounting a plate on the engine TAV mounts and using some block bearings. It would have to be custom built with how everything is on the bike currently.Hi Ralph,
Not sure if it really matters but here goes. EZ Q matic transmission offers a 56 tooth drive sprocket.
Ask Lynne about wheel building. Her wheels are very good and very concentric. https://mbrebel.com/
I thought this for ratio. (7" / 3.2") * (54 tooth / 11 tooth) equates to (2.1875) * (4.909....repeating) equals 10.73863636363636Good info Tony. Yes, the belt is concerning to me as well. After making some correct measurements it looks like an A-24 belt will fit nice and snug with having to be levered on and the belt touching the top and bottom of the clutch pulley. I'm willing to give it a go. From the info found online the A belts and AX belts are measured the same so an AX-24 it would be. The gearing I have at the moment is 3.20" clutch to 7.00" pulley and 11 tooth to 44 tooth. It didn't seem like adding ten teeth to the rear added much to the ratio in my calculations but I'm just dividing the numbers. Perhaps I'm way off. Was going to at least put the 54 on it but maybe going bigger and just drill an industrial sprocket. My calculations showed roughly 7:1 with the 54 sprocket.
Ralph, you echo my thoughts of being a legitimate motor vehicle. So far in SE Wisconsin, I am dodging arrest. Knock on wood.Knew I was missing something, thanks! My plans are to get licensed as a motorcycle but mainly stay on roads with 40mph speed limit max and only seeing fifty plus occasionally on short stretches of highway to get to the next road. I know having the bike papered is in a way the antithesis to motored bikes but I'd rather not have to worry about the hassle of being impounded or charged with something.
