HI guys - thanks for reading. When my 80cc w/ the red "speed"/NT carb is cold, it starts right up, and I can hit 35mph no problem on a 41 tooth gear. After about 10minutes, the motor starts to bog down at full throttle, speed drops, and it certainly doesn't have the same RPMS. Hit about 29, and thats it.
I've replaced the plug, the CDI, and the magnet. The top end has all new gaskets and ALL is tight. I did pop the cap off the jug, and the cylinder wall is kind of rubbery smooth, but NOT wet at all. Doesn't feel a bit oily. Strange? The plug is not wet also.
Running a 67 jet as I thought it ran better than the stock 70. Maybe I'll test again w/ the 70 back in, but wanted to get your thoughts. The dry cylinder is very strange. Running 24:1 full synthetic oil, as motor is still new.
Thanks.
Thanks.
