Worksman Rims on Whizzer
Shotgun
4
Question for those of you that have installed Worksman (drum brake-equipped) rims on their new edition Whizzer's.
I've noticed that the fork mounting bracket is bent so it will not fit between the forks (unless the forks are spread a 1/4") and it is too short to reach the attaching bolt thread on the fork. How have you guys dealt with these issues?
MotoMagz
1,817
1,154
Michigan
If you remove axle spacer from opposite side and replace with fat washers or thin spacer. Should give you some room
wrench
749
1,005
93
So Cal
Easy solution is to make a bracket
MotoMagz
1,817
1,154
Michigan
I was looking for a picture like that! Nice! I know they do have that bracket set up on some of the modern whizzer.
