First time builder here. So I bought an un-upgraded chinagirl kit off gasbike.net and they advertise that the bike will go 25-35 mph. Im using the suggested ratio for the break-in period(16:1) and I never moved the clip that's on the needle in the carb. I'm still in the break-in period (only 20 miles at most) but I feel like I should be getting more power. I seem to go 15, maybe a little less than 20mph at best, but i certainly cant reach 25-35, even on a long stretch of flat road.
One thing to note; I had to put the top head on the motor and when doing so, I accidentally pulled the piston out of the top head. I had to carefully align the rings and I made sure the hole in the piston was aligned with the holes in the motor. There is an arrow on top of the piston and I'm not sure if it has any significance, so it's possible I didn't install it correctly. I'm thinking my chain tensioner might also be an issue because it seems to be too close to the sprocket because I've never seen another bike that has a chain tensioner wrap about 75% of the sprocket in chain.
Here's the kit. Thanks in advance, guys.
https://www.gasbike.net/products/silver-slant-66cc-80cc-bicycle-engine-kit
