Fletchsd80
After having black stuff leaking out of either the head gasket, or the spark plug hole today when I got my engine running for the first time (probably oil although it was black like the grease?); I got out my torque wrench and tightened the head bolts to 13 pounds. A little while later I decided to try and up it to 17 just to be safe. One of them either stripped or broke off because it just turns endlessly now. I immediately lowered the others down to 15.
Does anyone know where I can get a matching bolt? Spookytooth has the entire head assembly, but I'd hate to have to pay for that when I just need the bolt. I will open it up tomorrow and see if it broke off or was just stripped.
Earlier when I took off the head, two of the bolts stayed in and the nuts came off, and two of the entire bolts came out with the nuts...is that supposed to happen? Are those broken as well? If they were broken I would assume that you couldn't tighten them when you put them back in?
