Hey moto,thanks for the comparison. The set up I'm thinking about would require the engine to be at around 110-115 degrees. Do you think that would be dangerous or would that end up returning the oiling to a proper level at that point?Check out this comparison. My buddy Racie35 turned a 212cc till the mounting plate was at about 105 degrees. I run mine cylinder straight up and down.
As long as the dipper is in oil and slinging oil..you should be fine. I would get motor were it needs to be with side cover off and see what’s going on.Hey moto,thanks for the comparison. The set up I'm thinking about would require the engine to be at around 110-115 degrees. Do you think that would be dangerous or would that end up returning the oiling to a proper level at that point?
sounds good. I'll see what I can do.As long as the dipper is in oil and slinging oil..you should be fine. I would get motor were it needs to be with side cover off and see what’s going on.
Hey moto, what are the dimensions of your engine stripped down? I forgot to ask earlier.As long as the dipper is in oil and slinging oil..you should be fine. I would get motor were it needs to be with side cover off and see what’s going on.
Pm’ed youHey moto, what are the dimensions of your engine stripped down? I forgot to ask earlier.
What kind of frame is that? Very nice fork.It runs fine. I put about 20000 miles on 212s this way.
It started life as a ‘69 Yamaha ct1. Fork is stock ct1; I shortened the legs by 3”. Made my own dropouts for 10mm axle and disc mounts as well, to slim it down for 100mm OLD from the 12x125mm stock spacing. I had a thread “212 build heavy duty” but had to delete the content. I’ll be bringing it back soon.What kind of frame is that? Very nice fork.
Interesting thought, would depend on where the dipper is, I know Sports car Pat says he added a bit of oil in the bigger engines. Almost have to take the side cover off to tell, what does AGK say?...........CurtWonder if anyone did a SolidWorks rendering with fluid/oil splash and flow dynamics. Lower figure illustrates a greater oil splash than the stock position, and explain excessive breather output. Depressurizing the crankcase may be useful too.
