Sldgehmmr
So my clutch is acting like the bucking bar is too short (Clutch won't fully disengage). I checked the bucking bar, (no adnormal wear) so I agusted the clutch to where it would operate but same issue occurred. So I cut a longer buck bar, it worked for a while but same issue reaccured. I've made 2 bucking bars longer than stock but clutch continues to do the same problem. I pulled the clutch shaft out of my engine and all is good (shear pin,spring,retainer caps all good). I'm at a loss and don't know what's going on any help is appreciated.
P.s. when issue occurs the clutch arm is bottomed out (meaning clutch arm is touching carb and dosent fully disengage)
