Did you even begin reading at the top of the post? By doing all I suggested, The OP should find if this is the case. I am waiting for his response. Let's see what he discovers at this point.check you drive gear nut it may of backed out and chucked out the keyway.
all good now?Did you even begin reading at the top of the post? By doing all I suggested, The OP should find if this is the case. I am waiting for his response. Let's see what he discovers at this point.
Hi my small drive nut keeps loosening up my clutch will work for a mile and then it'll just let go and usually if I tighten that small nut in the front that holds that small gear it starts working again but it repeatedly keeps loosening up is there any solution or do I have to replace the motor because it runs greatcheck you drive gear nut it may of backed out and chucked out the keyway.
I use a impact screwdriver to tighten that bolt if you cant then use some red/blue loctite on the srew.Hi my small drive nut keeps loosening up my clutch will work for a mile and then it'll just let go and usually if I tighten that small nut in the front that holds that small gear it starts working again but it repeatedly keeps loosening up is there any solution or do I have to replace the motor because it runs great
Thanks guys I appreciate the responses I've already used the loctite it keeps loosening up on me for some reason also tapped it with a hammer to tighten it up lasted about a mile I'm going to try a new lock washer
Thank you to everyone who tried to help. The culprit was a half-moon-shaped taper pin on the small gear on the right side of the motor. It had fallen out, it was a booger to try to put back in but it now works.
