I'm close to starting my new project; a custom version of an indian powerplus
Correct! Pictured is a gearbox, centrifugal clutch pulley and a pair of antique handlebarsOne parts looks like one of the pulleys used on a torque converter. Lets see more pictures as you go along!
Shoot, I guess I another part to buy. I feel stupid lol. Here's a link to the bars: https://www.ebay.com/itm/Stainless-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649Rear torque converter pulley, not a clutch.LOL Got a link to them bars?...........Curt
Thanks. Just so I know for the future, which one is the clutch that engages when revving the engine and what is the purpose of the pulley?Don't feel bad there's ALWAYS another part required! Good luck with your project.
Rick C.
Thanks!...........CurtShoot, I guess I another part to buy. I feel stupid lol. Here's a link to the bars: https://www.ebay.com/itm/Stainless-Steel-CrossBar-Handlebar-For-antique-Bicycles-Schwinn-Elgin/272747546055?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Ehhh sort of. My set up goes like this:
Centrifugal clutch is what you want...........CurtThanks. Just so I know for the future, which one is the clutch that engages when revving the engine and what is the purpose of the pulley?
A gokart transmission. I wanted something close to how those '16 bikes looked. Plus it'll come in handy when i add a side car in the future.What transmission is that?
Single speed with a foward, reverse and neutral gearActually if you have to shift a 3D clutch would be the best, is it 2 speed or more?..............Curt
I'd also considered the go kart transmission for my sidecar project & it's a good option for that purpose. What engine are you considering to power the bike?It's
The engine will hopefully be something special. Curt and I have been discussing A design for a v twin converted from an air compressor pump. I'll be testing it out in the coming months.I'd also considered the go kart transmission for my sidecar project & it's a good option for that purpose. What engine are you considering to power the bike?
Rick C.
Thanks for the support! I saw someone else make a similarly described design. Strangely enough, he was also very hesitant about his design. Something to do with a patent I believe. If and when i get a finalized model working, I'll be sure to release my schematics on the forums. It would really open up more opportunities for builders on here.V compressor motor conversions to fuel has been done, so it can be so again. The one I've seen was built as a 2 cycle & was pretty sweet though it was not mounted or intended for use on a bicycle, but rather just a display for trade shows and it ran & had an interesting exhaust note both on idle and under load. It started using a V pulley and 110 v.electric motor. The builder was rather cagey when it came to details of design, but my recollection was that it appeared to be a reed valve/case inducted design (single carb) I don't recall seeing a manufacturer's marque. I think both exhaust ports were on the curb side (right) but that may not have been the case, as this was several decades ago and I've slept since!
Best of luck sounds a project that will involve some time and a bit of ingenuity...coupled to much determination.
Rick C.
