Hey was wandering if anyone has cut off their clutch pulley and welded a bigger one on ?
I have 2 clutches so I'm open to modifying one.
Do you know what your gear ratio should be?
If not, do research and find out.
What pulley diameters do you have on the bike now?
By the way, your gear ratio is 6:1.We talked about the sheave and the clutch being to high if it burns up o well
According to online calculators 5:1
15 inch sheave converted from millimeters,
1/2 pitch clutch about 2.5 according to the shipping package.
Push come to shove I'll grind down my extra chain clutch that wasn't compatible for my build and weld on a pulley aproxximatly 4 inches the goal is 32mph "period."
If you think a 5:1 ratio will burn up your clutch,
then welding in a 4" pulley will burn it up AGAIN.....
only much quicker.
Run your bike with 5:1 gears, if you like.
When it burns up, you need to
install a SMALLER pulley.
Direct drive?Was thinking of welding the other clutch solid state simulating direct drive define smaller what's smaller then 1/2?
Direct manual etc what ever it's called I read up on all of that it's still trail and error like a CVT YOU CANT JUST SLAP PARTS ON sorry no offense but I'm not a moron, I am just cheap as ****.Direct drive?
Do you mean without a clutch?
Of course, you will use an idler puller, or a lever to disengage the belt, correct?
You need to google and read about pulleys and mechanical advantage.
Define smaller?
You have a 2.5" pulley.
What's smaller is 2.25", 2", 1.75", 1.5", 1"
What's smaller than 1/2"?
1/4", 1/8".
How can you be thinking of anything smaller than the size of your engine shaft?
You're not making sense.
Seriously, you need to learn more about pulleys and
the concept of gear ratios and mechanical advantage.
You should've paid more attention in school.
No offense meant.
Thank you I had a hard time finding a calculator that was the main problem.Use this calculator:
http://jimsitton.net/ratiocalc/
You need a 1.75" pulley with
a 15" sheave to go 32mph
with engine speed at 3600rpm.
That's with 8.57:1 gear ratio.
15/1.75 = 8.57:1
Well I appreciate all your help cause I know I can be annoying and paranoid about thing like this... I am not taking anyone here for granted all of you guys are like the back bone to my bikes vertebrae not calling anyone dumb it's just logical reference to proven studies.Instead of implying educations a problem, let's get to the bottom of this, if you've learned anything about studies about the A student vs the average C student you would know bookies can't do **** but they can talk all day about it.
LOL, bookies can't do *****.
Yes, let's get to the bottom of this.
So you're saying all these bike builders are dumb and learn the hard way.
Umm, A & B & some C students can talk all day about the problem,
do research.....
THEN accomplish what they need to do,
be it rocket science, IT, heart surgery, motorized bike building.
It's smart to think things through, ask questions, learn from other people's successes and failures, do what they did.
This is not rocket science.
If someone's done what you're trying to do.....
DO WHAT HE DID!
That's the smart thing to do.
I'm done.
Learn from your mistakes.
You can't say dumb but on a first build or a new upgrade you can be ignorant. If your ignorance is not rectified by doing some reasonable research, and you go all in you my be dumbfounded and hence the hard way or the highway. Thanks guys because of this sight my first build of a pk80 went so good after I read 8 out 20 top sticky threads.Instead of implying educations a problem, let's get to the bottom of this, if you've learned anything about studies about the A student vs the average C student you would know bookies can't do **** but they can talk all day about it.
do research.....
DO WHAT HE DID!
I'm done.
