Can whizzer wheel sheeve kit Fit my wheel?
TheSignGuy
Hello I was wandering can a 26 inch wheel sleeve kit fit on my 27 inch road bike rim?
Do not have the spoke size on hand could be a 32 spoke system cause the spokes are pretty gapped apart.
Need to know before Monday, having it sent to my job as soon as I get my answer.
If your 27" rim has 36 spokes, it should bolt on.
If your rim does not have 36 spokes, don't even bother to try.
It's 36 I miss calculated so I checked the photo of the spokes from the 2015-2017 models there all 36 spoke.....
Would I be able to attach a go kart centrifugal clutch to it or is that a idea?
If so what pulley size should I be using to god 25-30 mph?
What are typical belt sizes for rack mount styles.
Talking 3HP Briggs, 3600 rpm,
HP is not equivalent to cc in any shape form or fashion in older models.
Most 50ccs exceed that rpm 6 fold.
Cool I may straight trade my 10t for one...
As for tensioners would two pulleys on both sides of under the the clutch sound logical, welded that is on drilled out slide brackets thus making it easy to change the belt with a single socket size.
Kind of like this
T
O__O
T respesents the clutch
O represents pulleys.
Underline represents belt crush inbetween by tension between guarded spring in the middle.
When belt reaches proper rpm the two pillows expand outward resulting in stretching the springs as I feel lock washers won't maintain tension without destroying the metal where they are pulled by throw of the belt...
In addition I will have to cut a small piece of my fresh welded rack out as shown here.
