Creative Engineering
ok so using the calculator i should aim for 387rpm in the rpm box and then try get the gearing to suit...
No...The engine RPM should be the maximum that you intend the engine to turn...6,500 or less.
The first parameter at the top is your internal engine reduction of 3:1
The second parameter is from the 11T mounted to the gear reduction to the next sproket in the series...for this example I used 44T...you currently have 22T installed.
The next parameter is the final drive set. I used 20 to 28 at the rear wheel to give 30mph.
I've got to go for now...play with it some and I'll check back in the morning.
Jim
