I need advice any input welcome
dob1385
38
new mexico
Well I have my new engine on my bike. Its a thats dax bottom end with arrow
reed middle and fred head. The problem is the drive train and also the carb.
I have an adapter that bolts into a disk brake mount on the back wheel. I threw
the chain wich bound the back wheel and broke spokes. I want to be able to
keep up with traffic, whenever Im at full throttle things tend to brake I need
ideas for a solid heavy duty back wheel setup. Additionally my keihin carb is
problematic. the acceleration is poor. I was hoping for more low end torq with
the reeds but it is slugish. It definately has a higher top speed and the dax
bottom end keeps it a lot smoother than my previous engine. I have the
needle set to the lowest fuel seting with the choke halfway on to run it.
lowering the needle clip makes it worse. I think I need to down jet it but the
jets are not marked with the size and I have been unable to contact arrow.
do I need a moped hub and smaller jets? can I get a moped hub to replace a
26 inch wheel. when the engine picks up speed its fast but lagges on the low
end. Im sorry for the length no other choice.:-||
Tyler6357
1,293
294
83
Santa Barbara, CA
Is it 4 stroking? If so you will probably want to jet down to a smaller jet. However, its best to break the engine in before messing around with jets. I think the standard stock jet is a size .70, maybe you should try a .65 if it's 4 stroking badly. Also, the engine chain must be as straight as possible between the engine sprocket and the rear sprocket. If it's straight and it keeps jumping off the sprocket you might have the chain too tight, move the chain tensioner down a little bit, the chain should have some slack in it. I doubt your rim is the reason it's jumping the sprocket and you probably don't need to change it, it's probably the chain tension, just fix the spokes, true the wheel, and test it by hooking up the chain, getting the back wheel off the ground, and turning the peddles as fast as you can with the engine disengaged to make sure the chain won't fly off before riding.
http://www.ebay.com/itm/231458900645?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
dob1385
38
new mexico
I dont believe it is four stroking. It is just very slugish until I get up to higher
rpm's. like after i have gotten up to 35-40 percent of top speed wich I think is
about 30mph. even then if I open throttle to full it wont accelerate as fast as
if I have it 2/3- 3/4 open depending on speed. I dont think I have an air
leek. I
took gasket maker to some of the areas that could leak. The keihin has an
internal seal and I have the hose clamp on tight. When one checks for an air
leek do you spray with very soapy water and look for bubbles?
Thank you for your input and assistance.
ZipTie
750
82
28
Mpls Mn
leek. I
If its not 4 stroking then yes it maybe too lean. I do not have that carb nor reed valves, but your intake since its sucking air won't make bubbles but rather will suck them in.
Some guys dangerously in my op spray starter fluid where they suspect the intake leak And if rpms increase it signifies a leak. Possible fire danger here so not recommended. You certainly may have an air leak, could try running without the reed valve and see what performance is like. I would report back after that is tried. Or just try to look for bad gaskets, rough mating surfaces etc.
I believe with a reed setup you have an extra joint where un mixed air can get in .if your connections are not fairly perfect. A small amount of permastex maybe what the doctor ordered also. Your fuel petcock may be too restrictive also, starving the engine at higher rpms. Not uncommon either. Just try one potential fix at a time.
Zip
Tyler6357
1,293
294
83
Santa Barbara, CA
leek. I
Okay, if you can get up to 30mph I doubt you have an air leak. What kind of pipe are you using? Do you have an expansion chamber?
dob1385
38
new mexico
right now its a cut of exhaust. I have a sbp expansion chamber. Im learning to
weld to get it on now. Didnt have luck with the silicone and I broke the loop
where you attach the springs. I figured I would go with Jaguires calculations
and guestimmate header length for about 16 inches.
The bike is currently down. I was stupid and had the chain too short cause the
bike side chain was too short. This caused the chain to rub and threw it which
froze my rear wheel and busted spokes. Thankfully I ride low in the seat
and had front disk brakes and rear v brakes. Skiing on my feet and using
both brakes I just barely avoided biting the dust.
Venice Motor Bikes
Mar 20, 2008
7,355
2,034
Los Angeles, CA.
This means that the carb is too lean.
Whenever you add a reed valve, you need you install a much larger jet!
As for your problem with the chain... Can you post a few pics of your whole setup so we can try to spot any problem areas??
Tyler6357
1,293
294
83
Santa Barbara, CA
Venice is an expert, put in a bigger jet! Also, I have a SBP expansion pipe and I've got about a 16" header. I have found that I have tons of low end but the power band ends at about 85% throttle and after that I will be out of the power band and won't get any more. I've been thinking of cutting the header down some but I really like all that low end and don't really care about going much faster on it. I've already got a Fred Head with a squish gap of about .03" and my weight (bike, tools, and me) is about 265lbs, using a 40 tooth sprocket, your results might be different.
dob1385
38
new mexico
First let me thank everyone for there input I really apreciate it.
Tomarrow I'll take pictures. I finally got acces to a phone that has a decent camera.
Im down to get a bigger jet but when I lowered the needle clip it seemed to
make it worse. To complicate the matter neither the pilot or main jet are
marked. I was running a 65 on my old RT carb seemed to work well. I think I
might have opened the choke up a little when I dropped down the clip. Its got
five setings or notches. I droped from top notch to third. anyone know how I
could figure out the size of the jets? I dont have micro drills or anything like
that.
I should also add I dont have a air filture. I accidentally pulled it off the
rubber where it was glued, I stuck it bike on but it fell off while I was riding
never to be seen again.
dob1385
38
new mexico
ok so that little square links to my new photot bucket. If you have any advice on how to
do photos please share. I looked in the forum rules area but i couldnt find. Im probably
looking in the wrong place
