thingswithwelding
Im wondering if the AGK Sprocket I posted above in the first small sprocket picture is the same bolt pattern as the one I took of my bike?
tThe clutch came in a blow molded case and there are some washers with it. My motor is a one off in that it was a small snow blower motor that I had the crank shaft modified.
I do have a 212 Predator on the shelf and I'll look at it tomorrow and see if there are any special washers in there that fit. If it's needed I'm sure that it's there because they are very thorough in making sure the parts you need are there.
The aluminum sprockets are usually made by Azusa Go Karts. The one you posted looks like the ones I have. I'll check what size the bolt spread is and let you know.
Steve.
It shows the bolt pattern as 1.68"
Steve.
I don't think the way the clutch mounting on the crank shaft will differ from the 79cc to the 212cc or they would be making different clutches for them. The 1.68 inches is for the Azusa sprockets which yours looks like.
You might be better off emailing AGK and asking if the sprocket fits what you have. That will take the guess work out of it.
Steve.
Steve.
From what I'm seeing here the bolt patterns should match. If not, don't worry about drilling extra holes in the adapter as it won't hurt anything.
In fact for better longevity and a better fit, drill three new holes and tap them......then bolt the sprocket on and use the nylock nuts as well for extra measure. The reason behind this is that the holes in the adapter are a little too large and still don't line up correctly with the sprockets with the 6mm x 1.0 bolts supplied.
One more thing I feel is very important is the chain alignment when using these AGK aluminum sprockets.....make sure the alignment is perfect otherwise they won't last very long at all, just ask me how i knowIf alignment is spot on, they last a real long time.
Oh.....just one last thing (again)....#35 chain is the way to go...for the whole drive train. It's stronger (and lighter) than 415 or #41 for that matter. I've been running #41 for my secondaries on my 99cc and 212cc builds but that's going to change in the very near future as it keeps things more simple.
Have fun!
Reno, the clutches are two different sizes. There isn't a bushing. I didn't realize the smaller motors had a 5/8" shaft. Mine has a 3/4" shaft because the pulley was originally on the very end of it and it is longer that normal. Lots of room to play and and still a lot left over.
I understand what you mean by the slope on the shoulder of the crankshaft. Mine has the same thing. I'll look at the washers tomorrow and let you know if it has one.
Steve.
Here's the Bully measurements.
Inside the clutch that sits on the crank shaft 2-5/16" long.
Bell diameter is 4"
Distance from end of the clutch to the outside of the sprocket is 1/4"
I haven't used the Willard clutch yet but I wouldn't recommend it. They are metal to metal and I don't see that lasting to long. It was just something to use to judge distances until I found a clutch that I wanted. The better shoe type clutches often require adjusting (replacing) the shoes and springs until you find a set that works.
You can buy a box of different spring weights and shoes and then it's a matter of replacing them until you get what you want. Ask the supplier of Bully clutches if it will work on your motor. I bought mine from Pat at Sportsman Flyer.
It sounds like you are getting clutch chatter as you pull away. That is where the shoes grab the bell and then let go and grab it again. The shoes hold tight once you are going fast enough. That is one of the benefits of the plated clutch. When it makes contact it doesn't chatter unless the plate is worn out or oily.
Hope this helps with your decision and if you need more information please ask. I posted photos of my Bully clutch on my thread Indian Tadpole. Silver bear started it so it's under his name. Click on the link and it will take you to my Photobucket account where the photos are stored.
It's in the Motorized Tandems, Trikes and Recumbent Bikes section.
Steve.
I went down and looked at the clutch Reno and the keyed side is on the spring side and the key way is 1-1/4" long. There is 1-1/8" on the motor side. The supplied key is 7/8" long.
The instruction that come with it are some of the best I've ever seen. They"re in colour with measurement diagrams to explain how to maintain the clutch and there are six pages and the seventh page is a blow up of the clutch with the parts list included.
Steve.
