Hello, i just finally have been able to do a few long rides with out having any chain problems.. but anyways, i had my choke get stuck on the carb that i bought so i pulled the air filter off the carb and noticed a lot of oil and sitting in the carb and in the filter. i dont have reed valves on it and i took th boost bottle off because of it making it run poor. also i noticed that when your riding the longer you ride the less power the motor seems to have. but if you stop shut the motor off and restart the motor all the power is back till you ride for a little while. i know its not a heat problem. im thinking its because of not having reed valves and then having an expansion chamber and the bigger carb. the longer it runs the richer its getting? so where a good place to get a reed valve it? and are there offset intakes for the reed valves? because right now i have about 2mm between the air filter and the frame.
my pipe; http://www.ebay.com/itm/80cc-motori...137716?hash=item4af53f2b74:g:0BIAAOSwrmdTpZzG
carb; http://www.ebay.com/itm/18175924188...l?_from=R40&_sacat=0&_nkw=181759241885&_rdc=1
