sbest
I bought a Grubee Skyhawk, followed the instructions, but it together as it came and drove it moderately while breaking it in. I was quite pleased with it, am improvement over only pedaling. According to the website calculator at:
http://www.mne.psu.edu/simpson/courses/me240/bikecalc1.htm
it makes about 1.5hp to 2hp and has a 44t sprocket on back.
I put 3 tanks of gas thru it, swapped the plug to a NGK BPR6HS because the original 3 pronged plug fouled, tried the head plug forward and plug to the rear (worked better to the rear) and leaned the needle one notch. A fine wire in the main jet leaned it too much so I left it alone for now.
I did play with exhaust pipes too. I have the stock black catalytic pipe and a shorter chromed pipe. The shorter chromed pipe seems to be slightly stronger and quieter, but it is a close call, so I am using it. Uncapping the pipe is out of the question because I want to keep this sport unregulated, so I don't want to pi$$ off the neighbors with too much noise.
I have a couple hills to try for power, with the one at 45.021146, -64.630514 being about 10% grade. A great test for this little motor. Stock, it will not make it up here without pedaling, so let's see if I can improve that. Top speed on the flat is 59.9 kph.
So the first principle of trouble shooting is to return everything to as designed configuration. That is pretty much where I am. The next principle is to make minimal modifications (one at a time) so you can see what does what. Also best to start from easiest to hardest items to modify as well.
I figured the terrible gasket and port mismatch is probably the first thing to correct. So I pulled the cylinder and got some pictures. More coming of the corrections as soon as I can load the pictures...
