hserro1221
I just put a 80cc 2 stroke engine kit on a bike and I can't get a spark from the plug. I think it might be the kill switch, if it is how do I bypass it?
How are you checking for ignition? How do you have it wired now?
If you suspect the kill switch (doubtful problem) then simply disconnect it from the blue and black wire. I say doubtful because they don't fail as often as suspected here. Usually the problem is something else like the spark plug boot or bad connections at the splices of the blue and black wires.
Do what Greg said then connect the spark plug wire to the plug. Lay the plug against the cylinder head cooling fins (the place where the wrench goes must touch the fins) and spin the rear wheel with the clutch engaged. If the ignition system is working you should see a spark at the plug's electrodes. It takes a good spin to generate a spark so spin the wheel as fast as you can either by hand or pedals. Of course this means suspending the rear wheel off the floor so having a helper might be a good idea.
You have a bad ground connection. Take a look at the black wire where it attaches to the magneto coil. If that connection isn't good then there is no complete circuit, until the kill switch makes one. While you're looking check continuity (ohm reading) of the coil. You might also have an open circuit in the coil windings (blue wire).Also a not so common problem that I have found in my buddies bike is that his bike won't run unless the kill switch is in. Even when disconnected it won't run unless the kill switch is pressed in.
If the kill switch is disconnected there is no way the engine will run by depressing the kill button. Did you word that wrong?
Below is what it should look like.
