phoobarnvaz
A carb is a carb and the function is to feed gas so don't really make a difference if the engine is 2 or 4 stroke. You can even run a chain saw carb on a 4 stroke if you drill for a puls line for the pump,then the tank can be mounted anywere.
That's why these guys before the 90's and such were able to switch out the manifold on whatever engine they were using and use a custom carb for better performance or more power. I take it that I was doing exactly the same thing...only on a much smaller scale. Still fascinating that it seems like people are just starting to do this within the past year on the 4-strokes with the new manifolds.
I know another choice I had was a diaphragm carb for the 4-stroke. Seen them on sale at Dax and other places...but for myself...wanted something where I knew I could get the parts...especially since it seemed like Kings and Dax was the only place you could get a 4-stroke carb. The new manifold and the NT carb fit the bill.
What is sad is they done away with ajustable jets and went to fixed jets so now you have to chane or drill them,were you just had to ajust them before...........Curt
I helped rebuild carbs in the 70's and 80's on some cars I owned...but I don't remember ever coming across any that were adjustable. I seem to remember that you went to the same store you got your "kit" and told them what size of jet you wanted to put in the carb. Had to do this when I put a Holey carb from a 4-cylinder Ford on my VW Type 3 when we took off the dual carbs because they were too difficult to tune without special equipment.
I hate this...makes me feel old. ;(
