Hi guys. I have some noob questions so I came here since there are so many experienced members that hang out. Bike is a wally world Onyx, the engine is from DAX, a 50cc Gen 4, it says. The carb says "NTTC" and it's throat is actually about 13mm (the actual port, down in the flange.) It has the black air filter with 4 or 5 small inlets.
1) I have a 29", 48 spoke rear wheel. I know the standard sprockets are for 36 spoke rims, so there will be trouble mounting this thing. Is it possible to go with 6 bolts, 2 on each back plate some way or other?
Also, I notice some installs have the dished sprocket facing out, some in.
A video I watched said to face the sprocket to maximize chain clearance from the tire, is this right?
2) The Dax 49cc Gen 4 engine came without any oversize mounting parts. I am filling a cart at SBP and already put in the right front mount, but what about the rear? My bike has a 1 1/4" seat post, will it work with the basic clip and hardware in the kit? I didn't see any rear mount parts available at SBP, so I figure it might work without any special parts.
3) This town is at 837 feet above sea level. I don't know what jet is in the carb, but any idea what the right main jet might be? Carb is an NTTC.
Any info would be greatly appreciated. I like to get things close to right in one try, with some info I figure I can spare the bike a lot of take it apart/put it together/ take it apart...
Here's what's in the cart (so far) over there at SBP- it's all subject to change at this point. This thing is running into money, but it should be a lot of fun when running. All the plugs are for tuning/experimenting.
1 x NGK B7HS Spark Plug
1 x Exhaust Gasket (keeping a spare)
1 x Engine Sound Dampeners (might work, who knows)
1 x Carburetor O-ring (carb didn't have any)
1 x Plug Wire - High Performance (speedo should work)
1 x NGK B5HS Spark Plug
1 x NGK B6HS Spark Plug
1 x Front Engine Mount - Large Universal (sized for engine boss/ frame tube size)
I'll be adding a V brake on the front wheel.
Thanks for checking the thread and especially for any info you can provide.
Slogger the N00B
Slogger the N00B
