First Motor Bike ride today
MikeSSS
Bike is a Trek 920, no suspension mtn bike, 9 speeds in rear, 3 speeds in front. Tires are from Performance, Gotham 26x1.75 puncture resistant. Tubes are the thick puncture resistant, with lots of slime.
This bike rides very well but the tire/tube/slime combo has a lot of rolling resistance.
Motor is Subaru Robin EH035, a 33.5 cc four cycle, overhead valve, pushrod engine, with centrifugal clutch.
Mount is a Straton friction drive. Roller diameter measures 1.161".
The motor and kit performed perfectly, average speed was 16.2 mph for 18.88 miles. Gas used was 520ml or 0.137gal for 137 mpg. 14 to 17 mph is a very nice cruise speed, slower is quieter. Idle when going slow or stopped was 100% reliable.
Conditions were not ideal, there was a strong head wind for half the ride. I wore a sun brim on the helmet and this acted as a aero brake when riding to windward. Finally removed it and riding was much more pleasant.
All things considered, this motor and drive work extremely well.
Happy trails,
Mike
Those head winds really make you appreciate the Subaru engine. I used the Gotham tires for a while from Performance and was very happy with them.
Congratulations, Mike.
Those first rides are always good ones. Especially when they go as well as yours apparently did. Sounds like you did a good job on the install and now you're reaping the rewards.
Thanks for sharing your good fortune. Have fun and please, ride safe.
Have fun!
I am a big fan of friction drives, have 2 Statons, one with the same motor you have and one with a 33cc Tanaka. Love them both. They do not suffer the vibration issues of happy time motors and can easily be lifted off the tire for a zero drag pedal bike. And they go plenty fast enough.
It is sure nice to see someone come in with a good experience on a first run for a change.
Well done Mike ;-}
This instillation has the motor tilted slightly front down. For this reason, the gas tank on the motor will not fill completely. I do have the larger tank that installs on top of the motor mount and may install it.
I have a tendency to speed up going to windward, because the engine noise is harder to hear and use to gauge speed. On this ride I used a gps to measure speed, distance and time, it worked well but needs to be mounted on the handlebars.
Calculated rpm is 4250 at 14 mph and a bit under 5500 at 18 mph. This Trek 920 feels very nice at speeds up to 20 mph, I didn't go faster but calculations yield about 7300 rpm at 24 mph, the calculations used 5% slippage.
I did use pedaling assist at times, especially climbing or to windward. Pedaling is very easy, especially compared to after the motor ran out of gas and there were climbs on the way home.
Glad to hear you got yours running so nicely for the first ride, sounds like your rpms and speed are about right for that size engine, and yes, any wind resistance you can cut down on will make a difference.
Since you're in San Antonio maybe we can go for a ride on one of these weekends when I'm not so busy at the shop. Mine is good to go but I need to finish a few welds on my pipe and put it back on, I put a different front end on mine and it was hitting the pipe I made so i had to take it off and make a few small changes to keep the front tire from contacting it when turning.
My shop is located at 2011 Quintana road if you want to pay me a visit sometime and I'm open from 8:30 am to 5:30 pm or so during the week and I open up at 9 on saturdays and stay open as long as I got work to do. I also tinker with motorcycles and motorized bicycles when business slows down or after hours.
Yes nice ta hear "success" stories isn't it ? Great stuff ... enjoy !
Well, you have to figure that people that build and post lots of their builds pics were easy 'success' stories, in fact we build so many bikes here that a problem is a strange occurrence, but it is nice to not have most every 'nOOb' post being the same old common problems for a change.
Dave,
I'll contact you when I get the chance, been looking after some medical problems for a few days.
The Straton friction drive unit seems to be very problem free. It took about an hour to mount on the bike, later the throttle was mounted in a few minutes. I chose the Straton friction drive and Robin engine because I'm too lazy to tinker with things to make them work.
