A tool for???
Who can tell me what this is used for? It came with the kit I purchased and I have know idea what it is or used for.
Have you removed the 3 covers on your motor yet?
It's a double sided puller for the 10 sprocket and 20 tooth bevel gear
on the smaller side and pulls the clutch on the bigger side.
Hopefully you don't need to use it. :)
They aren't the most dependable. The threads can be a little dicy. Good luck.
I haven't taken the covers off my new 2 stroke but have on my old engine. Maybe I'll try it out on the old and see how it works.
Taking the covers off a new engine is one of the first things to check if everything looks OK and the bevel gear flat head screw is tight.
I haven't had too much trouble with the pullers.
i would save the puller for when you may need it as using them tends
to damage the threads.
Some of the pullers suffer from the same quality or the lack of as other kit supplied parts, I like most have several of the pullers. I found one to be made of descent steel and use it all the time, I coat the threads with grease to prevent damage or friction. So far so good.
mine is crappy steel, but keeping threads clean on both the tool & the part to be removed seems to work OK - used 3 or 4 times a day for 4 years here at the shop, I only dress it with the thread file every couple months or so
Would you recommend I grease the gears (a tab) and chain sprocket with high temp grease if needed too? My new engine is a Skyhawk 66cc.
Temperatures aren't high enough to require 'high temp grease'. Any good quality bearing grease will suffice. Some prefer the grease made for higher temperature applications because of the safety margin but it really isn't necessary.
I use Lucas Red-N-Tacky grease for everything that needs grease. Works great and also has a high drop temperature for use on automotive wheel bearings.
I agree about the grease too... if it stays put and protects the gears it'll work. I tend to use what I got in my garage or at the shop so mine does get the good stuff, but any decent quality bearing grease will suffice here. No need to spend a fortune on special greases, but if you got it, there's nothing wrong with using it.
