Who can tell me what this is used for? It came with the kit I purchased and I have know idea what it is or used for.
Have you removed the 3 covers on your motor yet?Who can tell me what this is used for? It came with the kit I purchased and I have know idea what it is or used for.
Taking the covers off a new engine is one of the first things to check if everything looks OK and the bevel gear flat head screw is tight.I haven't taken the covers off my new 2 stroke but have on my old engine. Maybe I'll try it out on the old and see how it works.
Would you recommend I grease the gears (a tab) and chain sprocket with high temp grease if needed too? My new engine is a Skyhawk 66cc.Taking the covers off a new engine is one of the first things to check if everything looks OK and the bevel gear flat head screw is tight.
I haven't had too much trouble with the pullers.
i would save the puller for when you may need it as using them tends
to damage the threads.
Temperatures aren't high enough to require 'high temp grease'. Any good quality bearing grease will suffice. Some prefer the grease made for higher temperature applications because of the safety margin but it really isn't necessary.
