No offense to dax as a dealer, he's really good for his service, but his information tends to be off. For example his 50cc 11hp engine listed he lists the peak torque as more, at a higher RPM, than HP (I think he listed 11hp @ 10500 and 11.5 ft/lb @ 11000). Which is impossible as HP is a function of torque x rpm /5252 (using the numbers I mentioned, that would make 24hp @ 11000, so unless power spikes radically, and he didn't list the right number, or the information is wrong). He also lists his balanced bottom ends as "hand drilled", which it was discovered they werent, they just happened to be straighter and rounder from the factory, and better balanced. Best practice is to measure it yourself. I am interested to know if it actually is 40mmOn another note i confermed at the dax website that the dax f80 is a 40mm stroke 1 pc crank with a 110mm con rod and the top end from the dax motor i built is what i am running on this build
