Clutch Screw
brobie15
10
AR
Does anyone know where I can purchase that little set screw that you remove when you adjust the flower nut on the clutch? I live in a rural area and have checked three local stores with no luck. The auto supply had one the same diameter, but longer. I have also checked several websites with parts and I haven't seen a clutch listed, let alone the screw. If anyone has any idea about where I could get one or more, it would be very appreciated.
Dave31
11,199
47
38
Aztlán, Arizona
Maybe this will help....... http://motorbicycling.com/showthread.php?t=3473
brobie15
10
AR
Thank you, fair racing. I didn't realize that you couldn't just use a regular m4x.7. without shaping it. I haven't been able to find anything in that size.I would really like to just buy some ready to use, but at this point, I would be willing to grind a regular one if I can find it. Don't know how it will work out, though, as I haven't had much grinder experience.
Pablo
Dec 28, 2007
3,698
33
48
Duvall, WA PNW
www.sickbikeparts.com
Yeah anything you find the head will be too big. It's dog easy to make one....I should make up a bunch someday as a freebie. Don't forget to take a little off the top! .shft.
Did the head on yours strip out like mine?.duh.
brobie15
10
AR
Thank you Pablo and Technocyclist. There is a Radio Shack 25 miles from here. I will check that on Tuesday. I stripped the threads on mine.The head is still o.k. I was so busy worrying about losing it because it was so tiny that I must have cross-threaded it. I am hoping that I didn't damage the threads in the hole as well. Pablo, I'll bet you could sell some if you made them up. I would definitely be willing to buy a few. I know it would probably take more of your time than it would be worth, though.
stuartracing
488
Gainesville FL.
Just use some locktight, then it won`t just come out even if the thread are stripped...My star nut rarely moves on my clutch,so far...I put a mark on it and never moved, but better to be safe.....
brobie15
10
AR
Great idea, stuartracing! If I can't locate a new one at Radio Shack on Tuesday, I am definitely going to give the locktite a try. I was starting to wonder what I was going to do as I haven't seen any around here that I could even rework to fit. The screw isn't that loose in the hole anyway, so I will bet the locktite will work fine. It will be easy enough to check if I mark the star nut as you suggested. Thank you.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
In a pinch, you could get away with "threading" (3/4 of a turn in, 1/2 turn out, 3/4 in, 1/2 out, use oil and you can re-tap the hole. Take your time) a slightly larger screw into the hole if you have stripped it beyond loctite. it's not a crucial fastener, it's just there to keep the flower nut from moving.
Alternately, use a tiny dab of JB Weld to hold in the stripped screw.
stuartracing
488
Gainesville FL.
That`s what I did....Found a screw around here and it caught a few threads , plus some tocktight and I was confident that it would be ok....
