Well Map,I guess this is bad news fer tryin our aluminum bushings eh?
Wait: an ALUMINIUM wrist-pin bearing? I missed that. Sounds like a disaster waiting to happen. And speaking of "waiting to happen", I'm really looking forward to Map's assessment on the brass bushing...I'd like to move over to one.
On a related note...and apologies for veering off-topic, I recently saw some low-priced CERAMIC roller-bearings I was considering for retrofitting to my bicycle's rear-hub. Hmmmmmm...
Remember, I only got 10 miles on mine before mine went bad.
I appreciate your advice/experience Map. Thanks for taking one for the team. I too could have argued the same points, tried and failed. You're saving smart people some time and bucks.I figured all along there was a good chance my engine would take one for the team during this aluminum bushing experiment, I made the argument that others could possibly make saying...
"the piston itself is aluminum so why wouldn't an aluminum bushing hold up as well as the aluminum piston itself"
I can say there was a slight reduction in vibes at a certain RPM which gave me about 2-3 MPH increase before the bad vibes kicked in, but not enough difference to make switching from standard pin and bearing set up to high dollar titanium pin and bushing, another thing is that if you use a bronze bushing on the titanium pin, you really haven't gained anything about just sticking with a steel pin and high quality needle bearing, the bronze bushing is heavier than a needle bearing so it pretty much cancels out the weight savings of using the titanium pin.
my final opinion is that neither the bronze bushing or the titanium pin are worth the cost or trouble, and it has been confirmed that they wont last as long and they don't provide any benefit, cool idea but and if someone just wants a Bronze bushing for whatever reason thats fine, but if they expect any noticeable difference in how the engine runs, sounds or performs.... they're gonna be let down because I can say been there done that and it just doesn't make sense to go that route in my honest opinion.
Map
Sounds about right... if the bronze bushing is heavy then it would be pointless to do the swap on a built engine that's already running just fine. I'll weigh everything and compare the weight against my original bearing and pin when my parts come in and report the weight difference but won't use these parts on the engine I have in the bike right now.
I might use those parts on the engine I'm building now, but may just decide to chalk it up as lesson learned and stick with the steel pin and roller bearing.
What would really impress me here for weight savings and better balance ability would be if someone with the right equipment could make a titanium rod for these, but then again, the cost might make that too impractical.
Solid mounting my engine to the frame by welding tabs for the engine to bolt directly onto really took out a lot of the vibes I was feeling at the seat and bars so I'm thinking mine was more of a resonance issue than a balance issue as it's now smoother than the first engine I had on it but this new engine was rough as **** when reved comparing to the previous one and now it's a lot smoother than it ever was. I'm sure it's still got the typical off balance that all these engines have but making the frame absorb the vibes instead of transfer them really helped in my situation.
I discovered that this engine is a tight case engine like the ones Fred is seeking
Map, how would one know/recognize these "tight case engines" that Fred wants?
