mapbike
I broke the metal handle on the lever wich was just really light cheap pot metal so hopefully the replacement I saw at kings will be better quality. Im not giving up on it but after just a few minutes test driving it i am hooked and need MORE POWER, it has a really funky exhaust on it that goes around the left side of the front tube then curves back and up around the right side then screws into a small expansion chamber then back into a tube then a coke can sized muffler and im guessing it is hurting my power and hopefully ill have the cash to replace it with a better exhaust soon. When you say dual pull does that mean it will operate the front and rear brake at the same time? If so can I set a bias to work the rear a little before the front? Im sorry for my ignorance but I know almost nothing about bikes and have not ridden since I was a kid.
The free-er flowing the exhaust is the better on these engines, and it is possible that the carb was never re- jetted for a better tune which is also very important for power and top speed, that pipe is very restrictive and if you can handle some extra noise put a high flow pipe on it and you'll notice a big power difference.
