...the lightening has already been proven to out rev and produce better overall poweron highly modified engines at the race track by people that are top notch engine builders, that settles it for me but again this difference was noticed on race built engines and may only provide small advantages on a bone stock engine that has nothing upgraded on it...
Map, have to totally agree with you on this. For 99.9% of stock engine users, the stock CDI does an adequate for the job. If you have a highly modified engine, then that is a different story.
The original CDI was manufactured to run on a 48cc engine. So if your trying to run the stock CDI on a heavily modified race engine, your at least 2 generations past the stock CDI. Heavily modify any engine and the ignition system isn't going to be adequate. Your pumping more air/fuel at a higher compression ratio.
I haven't seen any claims based on empirical evidence, such as test runs on a dynomometer - just subjective seat of pants reporting.
If easy engine starting is what your after, why not get a intake manifold with a boost port and squirt some starting fluid into the carburetor. Some members with medical problems have reported using starting fluid to start their engines and haven't reported any damage or engine problems.
Sometimes people run too rich of a mixture, in-properly use the choke or fail to use the tickler on the carburetor that makes starting more difficult. Or it's a possibility they're still using the stock plug and plug wires. Or how many have a high compression head. There are many reasons why the engine may be hard to start. It may not be the CDI.
A key switch is a nice theft deterrent, but how many members have reported hearing someone start their bike and take off with it. Most are probably silent walk offs. Most thieves probably know that you can buy a stock CDI for $10 off Ebay - Your term: "gizmo"
An ideal CDI would be one that has two pickups; one for low RPMs and another for higher RPMs - just as ideal as a carburetor with a slow and fast jets. This is due to the inherent nature of the 2 engine power band. Again, it would only be cost beneficial to someone with a modified engine or someone who's got too much money - but then again, there are those who buy higher octane gasoline even though their engines run just as good on a lower octane gasoline. To each their own.
Thanks for your honest evaluation,
Chris
AKA: BigBlue
Disclaimer: I don't own a HD Lightening CDI and/or a Jaguar CDI. I have no professional or casual association with the developers or owners of the HD lightening CDI, Jaguar CDI or any other bicycle engine manufacture and or distributor, or the owner and or moderators of this forum. My opinions are my own and I haven't been paid directly or indirectly by the developers and/or owners of the HD Lightening CDI, Jaguar CDI, and or any other bicycle engine manufacture and or distributor, or the owner and or moderators of this forum. My opinions are not an endorsement of any product mentioned in this post.
