That is the clutch shaft but shows the wouldref key in the picture, the key under the small gear looks the same.
stop.Took the plug out, rolled the bike, nothing came out the plug hole
I think you may have missed the part about the motor not turning at all as the reason for no compression.stop.
before you do anything else, pull the head, take the cylinder off
sounds to me with no pressure coming from the plug hole that you have no compression.
Indeed i did.I think you may have missed the part about the motor not turning at all as the reason for no compression.
Which thread would you like me to find for you, Wicked?Indeed i did.
Didnt so much as miss it tho
I did read but didnt process...
I think maybe the op should search for that thread, ir maybe a kindly mod knows where it may be...ahem 2door
