are there any motorcycle tires that will fit on 20x3, 20x4, 24x3, 24x4, 26x3 or, 26x4 bicycle rims
On a smooth surface you can go pretty fast but if you hit something in or on the road with a bicycle tire then you better be up to date on your life insurance payments.I wonder how fast can someone go on bicycle tires without some catastrophic happening?
Why mess with a suspension frame? That's not gonna help the load bearing capacity of the tires one bit. If you have to run the tires to max pressure then that's a real good sign that you need to go to a wider tire to handle the weight. Not to mention all the other things a wider tire solves. No mystery there. LOLWell 60 PSI is a lot, a suspension frame would have solved the bounding issue.
I run my chopper tires at the recommended 35 psi, same tire front and rear, with Suzuki K10 fork up front and a suspension seatpost, and the hardtail OCC rides nice and plush, the only thing that kept me from pushing on to 70mph back then was looking at my mechanical Krate speedometer twisted around twice, and thinking how awful it would be if it somehow seized up and snatched the front wheel. The speedometer drive tang or plastic gears in the gauge would probably yield first, but there's really no sane reason to go that fast on a motorized bicycle, lol! I'm fine maxing out at around 50 mph, and geared that way I have plenty of power to take off from a stop without pedaling the heavy chopper like a madman.
I see, its trollolo time. Well they're 4.25" wide tires, and I don't need to run them at 35 psi, they would work fine at 25, running them at 35 psi makes them more efficient, which means better performance. They're plenty compliant at 35 psi and ride like silk, and they are much lighter than motorcycle tires, which are completely unnecessary, and require under-inflation on a motorized bicycle to have enough compliance of the contact patch, especially if they are rated for a heavy dirtbike which weighs around 300 lbs without rider.Combined Load Bearing Capacity:
At max. 32 PSI - 988 lbs.
Speed Rating:
93 MPH
I will take these dual sport motorcycle tires on a hardtail bike frame over a suspension bike with bicycle tires......any day of the week. It's no contest. LOL
Under-inflation means tread squirm, and more susceptibility of the bead popping off or the tube getting a snakebite from the wheel on those potholes you complain about so much. The tire compound used on motorcycle tires is much more rigid than compounds for bicycle and moped tires, containing more silica. This means unless you load it up with 450+ lbs they're not going to grip the road around corners well. The stock 4.25 Schwinn chopper tires have too much silica like a all season motorcycle tire and are too stiff for a motorized bicycle, and wear forever, but have absolutely no grip. Of course motorcycle tires will wear better, at the tradeoff of grip that keeps you from washing out and tumbling across the pavement and becoming a human tire. I think you oughta try them out around some corners and hard braking before you try going at high speed (93 mph, hahaha, please) on pavement with dual-sport tires that have a tread pattern meant for mostly riding on dirt and gravel.
I wouldn't want to have to pedal those heavy motorcycle wheels, tubes, and tires around, it kinda defeats the purpose of a motorized bicycle. Might as well get a plated dirtbike off of craigslist at that point and put supermoto tires on it for the street, then you'll have hydraulically damped front and rear suspensions, a comfortable seat, severe acceleration, hydraulic brakes, and something that can eat up cars for lunch rather than getting run over by them. With a couple of my bikes I've run up against the motorized bicycle/motorcycle boundary, and have backed away from that idea and have focused on getting the most out of bicycle components, because they work much better than simply adding more big and heavy stuff, as its a point of diminishing returns.
Most slick or street treaded bicycle tires are more than sufficient for speeds over 45 mph, if properly inflated. Using big fat tires for suspension on a fixed frame bike is in my opinion a poor band-aid for a real suspension system. Putting all that rotational inertia on a motorized bicycle means more mass the engine's gotta sling around and accelerate, rather than putting compliance in the front and rear suspension so you don't hammer the crap out of your wheels and tires.
When I was in SoCal I thought the roads there were some of the best paved in CA, they even smooth out the curb cuts for skateboards and lowriders entering parking lots, I have no idea why you'd need dirtbike tires and wheels to ride the street there.
Whatever, I can see you're justifying your decisions to yourself by debating with me, to each his own.
40+ MPH at night, in L.A., on a motorized bicycle with 2.6" bicycle tires. You don't know what terror is until you've tried that at least once, even with a headlight lighting your way. Not because of any cars that might run you over at any time, but because of hitting any myriad of things in the road. I did it all the time, but being lucky will only last you so long. My luck almost ran out one time. Oh so close. LOLI didn't spend much time in LA, just Hollywood for a night, then went north for a couple days, then back to a hotel by LAX before I flew out, so I'll take your word for it.
In the Hit and Run & Pedestrian Killing Capital of America (Los Angeles), I can actually say that I'm more afraid of the road conditions than I am of being run over by a car.I didn't spend much time in LA, just Hollywood for a night, then went north for a couple days, then back to a hotel by LAX before I flew out, so I'll take your word for it.
