The cool thing about the smallest jet is that you can drill it out. Of course, the best way to jet tune is to run it rich with a big jet and step it down to clean up the top end pull, doing spark plug checks after short (warm) full throttle runs, and when you get a plug read that is too lean or lighter than a milk chocolate brownish gray, then step up to a richer jet for safety of the engine. Sometimes the optimal jet can be in between available jet sizes, but you have diy options; you can drill out a small jet with tiny drills, peen the hole slightly closed with a center punch to close it up slightly, or use a drop of soft solder applied from the screw-head side to close the hole up and re-drill.
