rock out,
I lifted these form a post from Barelyawake from over three years ago, hope you dont mind B.A.
this is another thing you should do to the NT carb to help the lower to mid mixer, on all of my engines while running the NT carb I have needed to raise the clip on the needle to the second from the top notch, the pix here will show what you will be seeing when you remove the carb slide, hold screw on part/top where cable is and then push the slide so that the spring is compressed and you cable remove slide form cable so that you can adjust the clip position, use needle nose pliers to snap clip on and off of the needle if that clip flies away theres a good chance you wount find it, so dont do the work in the grass or dirt get on a good surface so if the clip does fall you have the best chance of finding it.
here are the pix
notice in last pic where clip is on needle, this is where most of us run it and it seems to work out best in that position.
This isn't the final fix for a carb that is running to rich, you will still need to jet the carb down to get the best tune and for the engine to run at its best, this is only an adjustment that will help along with the smaller main jet you need in the carb.
hope this help.
Map
![reddd reddd reddd](https://motorbicycling.com/images/smilies/reddd.gif)
