Puch Bobber
dracothered
973
Howell, MI.
I cut up two Murray swing arms and stretched the one.
The rods are to line up the pieces and to add strength at the joint.
Added about 3 1/2 inches to the swing arm.
One side all welded up.
dracothered
973
Howell, MI.
After doing some reading and a test assembly with the rear wheel on the swing arm I have come to the conclusion that it is becoming a hard tail with a sprung seat.
The shocks that are there now will be going bye bye, to be replace by a seat stay.
dracothered
973
Howell, MI.
A hard tail it is now, which takes care of many a worries over the shocks and if they will work right or not. Still need to weld the other side on.
Try to guess what I used to make the seat stay out of...
dracothered
973
Howell, MI.
Here is my Puch E50 50cc engine that should put out a little over 2hp.
I wonder it I put an extension pipe on the muffler if it would effect how it works?
dracothered
973
Howell, MI.
The front seat mount is made, now I have to wait for the rear seat coil over shock to come in so I can mount it.
Here is two different tail light positions that I am considering, of course neither is in the exact position that they would be mounted. I also have a couple small tail lights coming that I want to mount just above the rear axle on both sides.
dracothered
973
Howell, MI.
To be honest the more I looked at the top tube alignment the more it bugged me so I moved the back of the top tube.
