Hi KC, thats a great idea. U may need to put the ohm meter on the trimpot "out of circuit" to get an accurate reading, but with the trimpot's being a precision, close tolerance item (& having a linear resistance taper), u might only need to calculate the adjustment screw positioning for a 16 ohm setting once. They should all be ballpark close enough for the same setting to be near enough. After reading a few u'll know for sure if this is the case.
Going back to ur question about spark duration, a CDI produces a really hot spark (their use in 2 strokes took off as this helps burn off oil deposits), but it is of pretty short duration & there's nothing we can really do in regard to the CDI to remedy this. The spark is generated when the charge cap across tge primary winding is discharged causing the built up magnetic field to colapse, so probably coil design more than anything affects duration. Something I need to look further into. Cheers
