Performance CDI layout and schematic diagrams
I wanted to say that after trying the advanced timing circuit i didn't like any of the settings. I would just stick with the original post in this thread.
If you are having trouble be sure to ground your coil to the block
Grounding my coil to the engine block helped alot. No more shocks from the gas tank, I just run alligator clips from coil to block.
PS. Digikey Parts list is on page 6
The one part number doesn't work, i found a replacement
Replace 1.0KH-ND with CF12JT1K00CT-ND
I was just troubleshooting a test unit a noticed that diagram does not match the schematic.
In the schematic only the 390 is touching the transistor base and in the diagram the 1K and 33 are touching the base....
4_photo0009_zps76b13025.jpg.html
3_photo0007_zpsf21a8b62.jpg.html
